Hobby Fanatics: How to take care of your PVC figure. Must Read!! - Hobby Fanatics
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
How to take care of your PVC figure. Must Read!! What is PVC, Resin, cold cast, ABS, etc.
#1 User is offline   baibaiman Icon
  • Group: Member
Posted 06 February 2008 - 12:54 PM
Hi all,
I just join this forum but I am not a noob :lol:
I was active on other figuring forum and I am an anime figure collectors since 1995.
I also have study many things about figuring and others by reading a lot of books.
Here, I just want to share something to all of you as Toy figure lover.
This articles was made by me, some of them was taken from others.
Please post here if you have any other question. I might be able to help.
What is PVC, Resin, cold cast, ABS, etc. --> Taken from http://www.riuva.com/?p=301
COLDCAST
Basically, no heat is applied when the material is set in the mould. By mixing two types of liquids, a tough plastic compound is formed. It is the most expensive type of material for figure. Nicer and more live color compare to PVC.
POLYSTONE
Polystone is the common name for Polyethylene, just another plastic. But there are two main types, High and Low Density. High density is used for the figurines. Polystone offers good resistance to moisture, impact, heat, sunlight, cold and has good rigidity. I mean good compared to PVC. Everything here is compared to PVC.
Polystone distorts of about 80 degrees Celsius. It is not that ductile, lighter than water, and can be moulded, machined, and joined together using welding (difficult to glue). It’s a thermoplastic as well, meaning it can be heated and reshaped and cooled. This is easy to mould and rather durable. The higher heat resistance and rigidity also means figurines do not lean or distort, or worse, start degrading in sunlight. But for this added quality, polystone figurines are more expensive than PVC ones and the selection is a lot less.
Unlike PVC which is more ductile, Polystone does BREAK because of the higher rigidity. So shipping overseas is a bit more of a risk for these. Use EMS at all costs.
And yes, it’s also known as polyethene, the plastic bag. So people who have been fooled by the fancy name, please hang your head in shame.
Poly Vinyl Chloride (PVC)
PVC is one of the most common plastics used in the world. It’s quite similar to rubber and the toughness/malleability of PVC is dependant on the plastisers added. More plastisers = more softness, since they straighten out neatly the long macromolecular polymer chains into neat rows. Some figure collectors complain of an oily film after a while and I would think this is due to the plasticisers migrating to the surface of the plastic. Small plasticiser molecules are pretty mobile and after a period of time, they accumulate on the surface to produce a oily crud.
This is also why PVC tends to get a bit crappy and brittle after a long time. Oh yeah these plasticisers are quite toxic too. And if you have a fire at home, dump your figurines at them to extinguish it, since the chlorine produced retards the flame. Btw, some plasticisers are thought to reduce the quality of MAN SPERM.
A very large percentage of the figures sold are made of PVC. From gashapon, trading figures to 1/6s, these are mainly PVCs. Cheap material cost, easy of moulding, ductility (it won’t break much, just bend) are the reasons why it is used.
Never leave them in the sun. Ultraviolet rays produce free radicals on PVC, chlorine free radicals, that combine to form chlorine gas and the material is decomposed. The sun also heats them up and PVC distorts at a temperature of 60 degrees Celsius. Being a thermoplastic, you can actually heat it up and bend it, then cool for it to maintain that shape.
PVC, due to the addition of chlorine atoms which have a pretty high molecular mass compared to C and H, is heavy for a plastic.
ABS (Acrylonitrile Butadiene Styrene)
ABS is commonly used for the bases of figurines. It’s pretty recognisable, just think of LEGO blocks. That’s what they are made of. ABS has good impact strength and is not really flexible but rather stiff. These properties plus the glossy surface make it a suitable material for figurine bases. Interestingly, unlike all the above, ABS is not a compound but just a blend of 3 types of plastic.
"ABS is an amorphous thermoplastic blend. The recipe is 15-35% acrylnitrile, 5-30% butadiene and 40-60% styrene. Depending on the blend different properties can be achieved.
Acrylnitrile contributes with thermal and chemical resistence, and the rubberlike butadiene gives ductility and impact strength. Styrene gives the glossy surface and makes the material easily machinable and less expensive." -Designinsite
ABS is more expensive than PVC and is slightly lighter too. Its price is commonly used as the dividing line between common plastics like PVC and more expensive industrial plastics. ABS has a higher distortion temperature at 75 degrees. Its properties are also easily modified by varying the proportions of its components. Its natural colour is an opaque ivory but dyes can be applied.
Now, lets begin step by step to keep your Collection perfect for a long long time.
I have 10 years old PVC figure and it still like new. No cracking or discolorized.
Here is the simple list of how to taken care of your PVC figure:
1) Keep it on cool temperature. (Hot temperature will cause your pvc to produced oil and it will easily crack in the future). Why it will produced oil? What is that? Read above!!.
2) DONT EVER PUT YOUR PVC DIRECTLY TO SUNLIGHT. Dont put them near strong light that produced heat wave, e.g halogen lamp and filament bulb.
3) Once every few months, put your figure inside freezer for about 20 minutes (Not too long).
4) If by any chance your figure starting to produced oil (Because of heat), put your figure to freezer for 30 minutes to 45 minutes.
5) Use blower to clean your figure. Personally, I use hair drier to blow all the dust (!!!!! REMEMBER TO SET THE HAIR DRIER TO BLOW COOL AIR, NOT THE HOT AIR). If you rich, use dust remover that used to clean up computer part or other electronic stuff.
6) Do not clean your figure with chemical liquid. No warm water as well. If possible avoid water; only use small amount water to clean very dirty part of your figure.
7) If you have a hard time to remove the figure from the stand (most of them are made of plastic), do not use force. Just put the figure inside the freezer for 5 to 10 minutes. It is because plastic will shrink and expand more then PVC, coldcast, etc..
8) If you have more then 1 figure stand close to each other, please make sure dont let them to touch each other. After long time, it will leave a mark ont he other figure.
9) (THIS IS NOT TOO IMPORTANT. IT ONLY HAPPEN WHEN THE FIGURE USED CHEAP PAINT. Famous brand such as Max Factory, kaiyodo, alter, good smil company, etc.. will used good paint) Try to put a plastic to every joint that removeable to avoid direct contact that will leave a mark after a long time. Do you know the reason, why manufacture always put a plastic bettwen the joint that removeable when you bought a new figure? It is because when they touch each other, after long time, it will leave a paint mark.
10) This is for PVC figure Only.
AVOID puting heavy object e.g. weapon, items, etc.. on your figure hands. It is because PVC will bend over time. For more info about this or how to fix this, go to http://www.happysoda.com/archives/142
How to Fixed broken part of you figure:
1) Clean both part. Make sure no dust stick on the broken part that you are going to glue.
2) Use Super Glue. Gel type work better because it will not spill.
WARNING!!!!
DO NOT use Glue special for PVC. It is because PVC glue will melt the PVC in order to stick them. You do not want to melt anything on your figure.
3) Before apply the super glue, make sure that the broken part have flat surface or match in the crack (This is to ensure that enough surface for the glue to stick).
4) Apply a very tiny amount of the super glue to 1 of the broken part (dont apply on both side). Wait a few seconds before put them together. CAUTION!!! IF YOU OVER APPLIED AND THE SUPER GLUE DRIPING TO THE OTHER PART OF THE FIGURE, YOU ARE SCREW. IT WILL LEAVE A MARK FOREVER.
5) After glue them together, do not touch your figure for a few hours. It is to make sure that the glue really dried up.
6) Sometimes the color of the figure on the broken part will a bit decolorized. It is normal. Just use permanent marker with the same color of the figure and just color them back (DO NOT USE IN A LARGE AREA).
Hope this can be a help. Thank You for reading.
Please comment and correct me if I make a mistake.
Please add something when you have more way to take care of your figure.
0
#2 User is offline   NGM Icon
  • Group: Member
Posted 08 March 2008 - 12:07 PM
I don't know about you guys, I've been into this hobby for 8 years. Only now that i learn the meaning of those terms.
Arigato Qusaimas = plenty of thanks baibaiman :D
0
#3 User is offline   EdZ Icon
  • Member v.1
  • Group: Member
Posted 08 March 2008 - 01:53 PM
Shouldn't that be 'gozaimasu'? Or are you using a different romanisation system?
0
#4 User is offline   rebekkajoost Icon
  • Comming holidays ideas
  • Group: Banned
  • Interests:Gardening
Posted 20 December 2008 - 09:17 PM
Sorry if I am post in "Model Discussion" category, but I am think it's the most suitable.
Stay not long time before christmas and happy new years holidays. I am have big famaly and now I am even not know what kind of gifts make to my friends and famaly.
So my kids, husband, siters, brother and my and husban's parents. :)
Who also don't know what to present to they? What gifts (not expensive) I can present to my famaly? Any ideas?
What your friends and parent get from you on christmas? :)
Thank you!
0
#5 User is offline   OneGanjaLady Icon
  • Cannabis Seeds
  • Group: Member
  • Interests:Baseball
Posted 22 December 2008 - 12:13 AM
Buy cannabis seeds, worldwide, UK and US cannabis seeds delivery, growing canabis, best & cheap cannabis seeds.
New genetic of cannabis seeds. Guaranteed UK, US and worldwide delivery. Save your money and buy cheap cannabis seeds. Safe and confidencial delivery. Easy seeds growing. Free shipment. Discover and proven.
Tags: cannabis seeds, cannabis, seeds, marijuana, pot, skunk, ganja, strain, growing, buy, cup winners, feminized, cannabis seed, canabas
P.S. Cannabis seeds delivered discreetly worldwide. Best cannabis seed prices on the internet!
0
#6 User is offline   yh1987 Icon
  • Group: Member
Posted 14 January 2009 - 10:58 AM
thanks for this post guys. i was tidying up my stuff and i came across a whole bunch of figurines that i bought over the past 4-5 yrs. i have no idea why it turned oily and kinda sticky all over the pvc and abs surface cos i stored them in a cupboard away from the sun and any source of heat. but anyway i tried out the method of putting the figurines into the freezer. it did work to some extent cos it did reduce the stickyness on the surface but still there seems to be a layer of that on some of my figurines? anyone facing the same problem or does anyone have a solution? if i have a surface that is pretty screwed up do i wipe it off with a clean cloth or just leave it? i am afraid that if i wipe it off the paint goes off too.
for storing figurines that are in odd position how do u support the figurines so that it will maintain its upright position?
anyway great post i recommend this post to be stickied. really helpful for me. thanks for this maintenance guide
0
#7 User is offline   theonlykisboi Icon
  • Group: Member
Posted 01 December 2009 - 03:40 PM
Hi, uhm, i'm, new to this site and i was googling on how to take care of my figurine and i found this, however while i was removing her head i accidentally got some black paint from her pistol onto her hair and i was wondering what would be the best way to remove that paint as it stands out, and has become an eye sore to me.
The figure is named Comic Aun Lala, with pink hair
thanx in advance
0
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
