Neosakai, on Jan 22 2005, 09:21 PM, said:
Thanks.... Guess I can really go for the cheap one.....
Err one more question.....
What's the difference between cheaper and more expensive compressors? They just provide air.... What do the more expensive ones do that the cheap ones don't?
Noise, horse-power, storage capacity, psi & cfm ratings, durability, etc. are all dictated by cost. Will you be doing anything else with your compressor besides painting? Is size or noise a factor for you? Is cost an issue?
An airbrush really shouldn't put any significant strain on a small "shop-type" air compressor. If you don't plan to do anything except paint models with it the I would get a cheap one. (i.e. $79.00 to $99.00 at various locations) You can power a few basic hand tools with them and some will have a regulator. Some models are noisy while others are bearable for indoor use. All should be compatible with 1/4" NPT threads; you can get quick relases for your hose at the hardware store. If you go this route be sure to buy a moisture trap. All said and done you will spend about +/- $100.00 to $150.00 for a small compressor, auxillary regulator/ mositure trap, supply hose and all required fittings. If noise isn't an issue then this is the rig I like to suggest for the value.
If you buy an airbrush specific compressor from an art suppy store be prepared to spend more money than you would for a shop type compressor. (+/- $150.00 to $1,200.00 and up) The upside to that is that most artist's air compressor should be ready to go out of the box and they range from very quiet to silent. Unless you are doing production work, t-shirts or commercial illustration it can be hard to justify the cost of a high end artist compressor. I have a silent compressor but in hindsight I wish I hadn't bought it; too finicky.
You can get airbrush compressors at the hobby shop but most of the ones I've seen don't have much (if any) storage capacity, low psi & cfm ratings and tend to be over-priced for what you get in my opinion. (That's just my opinion)
All things said I prefer using my 5 hp shop compressor because it suits my specific needs; great if you live in a house and have a shop but a really bad idea if you live in an apartment.
What do you want in a compressor?
Hope that helps some.
